Twin Merc 5.0L MPI's - different flow rates...
pwrplay
Hi guys,
Would anyone have any suggestions as to why my Port engine burns more fuel then the Starboard engine at any given RPM.
When I have both engines at cruise (3500 RPM's) I can burn anywhere from 1 to 2 GPH more on my Port Engine.
This is even evident when at idle (both engines about 650-700 RPM)
I am getting my fuel rates from a Lowrance LMF-200
The boat is 2006 Four Winns Vista 318 with twin 5.0L MPI's.
Thanks
krisnowicki
Re: Twin Merc 5.0L MPI's - different flow rates...
what are you fuel flow rates as of now?
pwrplay
At 3500 RPM's the Starboard side reads ~10.2 and the Port reads ~11.5.
At idle Starboard reads approx .6 to .9 and Port reads .9 to 1.5
Now these figures do jump around a bit while running , but the Port engine usually stays higher then the Starboard
JustJason
try reversing the fuel flow sensors(or leads) and see if the problem follows the sensor or not
