Turns to port when trolling
TheJohnsonTrolls
I have a 1974 Johnson Sea-horse 25hp that turns to portside when I take my hand of the tiller. Why is this and how can I fix it?
dew2
Re: Turns to port when trolling
There's a tension screw on the??? Well I believe it tightens the pilot shaft Look on the leg just below the motor you'll see a screw with a spring under it some where.It tightens the rotation of the motor,tighten it and it wont pull from centrifical force.
TheJohnsonTrolls
Yep. I know the screw your talking about. I will try to adjust it next time I am out on the water. THANK YOU!
