turning point prop failure
joien
I recently bought a turning point prop that's 13 1/4 x 17 to replace a 19 pitch in the same diameter. The third time out I was in 30' of water and doin bout 30mph all of a sudden the prop lost a blade. I didn't hit anything, its as if the seam pulled apart where the blade meets the hub.has anyone had any trouble with this or did I just get a lemon? I emailed turning point and I sure hope they can replace my prop. the other two blades don't have so much as a scratch on them.
SkiDad
I say you had a defect and they should replace. I have one and it's been fine.
Texasmark
Me too. Besides, if you mention that you frequent the iboats forums and mentioned your problem on here you will probably get stellar service from them. Grin
