Tune up time
rickasbury
Master Chief Petty Officer
So, have been out of the water with my 2006 350 mpi motor and bravo lll. This will be our third season in the water and the last two seasons I have replaced oil and fuel filters and oils each year. First year I replaced plugs but that's all I've done. I know those are main things....what else should I do going into this season? Runs fine...has about 300 total hours on it...closed cooling- has new coolant.
alldodge
Thinking you have replaced the raw water pump impeller and just didn't mention it
Since its running good, just keep doing what your doing.
Check the serpentine belt for cracks and check/clean electrical connections for corrosion and go boating
