Re: Thinking of trying to rebuild 18 hp Johnson
Ok guys I need some help now. Today I'm expecting my last piece for the lower unit. The shift rod cradle. Here's some pics ,and I got a couple questions. 1st pic is everything I got for LU rebuild. 2nd pic Is everything I plan on using at this time. The 2 items still in bags are the drive shaft O-ring and the water tube grommet. That I will install when reattaching the lower unit. The rest of the stuff appears to be extras. 3rd and 4th pics are showing widths of drive shaft seals. 5th pic shows the actual amount or rubber in the drive shaft seal. 1st question is about the 3m 847 to which parts ,and how much should I use. IE heavy,med,light. 2nd ? what is the best way to reinstall the seals. 3rd ? is the seals themselves they are smaller in height than the ones I removed. The prop shaft just a little ,but the drive shaft one appears to be only about half as tall as the original, and there is vary little actual rubber inside it. I was sent 3 seals this size. My question is do you guys think I should use 2 of these seals in the drive shaft hole as that appears to be about the height of the original seal. I plan on installing these parts. Shift shaft o-ring and seal,prop shaft O-ring and seal, spaghetti seal, drive shaft seal and water pump plate, housing and Impeller. Of coarse as well as reassembling the LU gears ,and installing drive and shift shafts,plus filling with gear oil. So any tips for any of this stuff would be appreciated. Thanks in advance for any help.
