trying to pin point problem
sandspike
if carbs are just a little out of sync,what motor be doing. 73/65hp/eninrude
Solittle
Re: trying to pin point problem
Ahhhhhhh - - - not running well. The cure is to do a sync & link adjustment. Follow the procedure in your shop manual.
rickdb1boat
Mostly, you will have from idle to midrange problems. In other words, it will not get up and go from idle as it should..
sandspike
i think thats it. hey rick,when i shift from n to f, if i dont do it fast, it will stall or starts to bog ,i give it a little more gas but you have to do it easy,to much gas and it will stall also i kinda have to almost play with the throtlebut once it catches it runs fine
