Trying to ID old Evinrude
DaveH8302
Trying to find what year and HP, Model of old Evinrude.Has the # R 19 P stamped on clamp bracket,it's a twin 2 cycle and has a Tillotson carb. Copper soldered tank with a tag full of patent dates from 1911 to 1919 w/tag that states motor # N 2194? Thanks Dave
CATransplant
Re: Trying to ID old Evinrude
Well, in 1927, there was a model R Evinrude. It was a 4hp model. Does the outboard say Evinrude on it anywhere?
CATransplant
A little more research shows that the Evinrude R Sportwin did use a Tillotson carburetor, as well. That would make it a 1927 or 1928 model.
CATransplant
Check and see if you can find a model number on that carb. If it's a MS-4A, then that matches the 27-28 R Sportwin. If it's an MS4B, it matches the 1929 R Sporttwin.
Chinewalker
There was a model N along about that time, too. The carbs are often broken or missing as they used a cheap pot metal in that era. Early models had the soldered tank, while later ones had a spun cast tank. They can be made to run quite nicely, although some flywheels may need to be re-magnetized...<br /><br />- Scott
CATransplant
The Model N, a 2.5 hp outboard, used the Tillotson MS3A carb.
DaveH8302
Originally posted by CATransplant:<br /> Well, in 1927, there was a model R Evinrude. It was a 4hp model. Does the outboard say Evinrude on it anywhere?
DaveH8302
DaveH8302
Yes it does riht on top of the flywheel cover
DaveH8302
Originally posted by CATransplant:<br /> Check and see if you can find a model number on that carb. If it's a MS-4A, then that matches the 27-28 R Sportwin. If it's an MS4B, it matches the 1929 R Sporttwin.
DaveH8302
it is a ms4b, any idea where I can get a parts and info, it's in very good shapr but ahhas no spark...Thanks a -lot... Dave
DaveH8302
Sorry for the bad post's,I got click happy with all the info !Any info on where to find parts and tech. manuals,I've got no spark an it looks like a mag. ignition. I would like to see this one run. Thanks too all.
shaungregor
hi iv got a 40 hp evinrude and the only stamp on it has the model and the serial number on it just wondering the year model thanks
shaungregor
alden135
fordsrule, try posting all your #'s in a new post all your own. More people will see it and your moke likely to get an answer.
