Trucks Submerged in Water...
HollaGeo
I've watched a few youtube videos on boat launching and what not. I couldn't help but watch a few where trucks were completely submerged in the water. How does this happen???
boaterinsd
Re: Trucks Submerged in Water...
I would have to say the 1% rule applys in this situation. I could maybe have some consideration in the event you are driving a straight stick. But they arent all that common anymore. Otherwise plan on using 4 wheel drive to be safe. The parking brake is also a safe bet, but check all your stuff before you need to use it. I will also reccomend you have your or a repliable shop/ mechanic check over your vehicle. :)
HollaGeo
What are you talking about???
Sixmark
Master Chief Petty Officer
99.9% of the time it happens because of lack of common sense or preperation.
People forget to use the parking brake and put alot of stress on the transmission, standards may pop out of gear and automatics may jump the park lock pin......or it may even shear off.
Alot of people will claim that you should use 4 wheel drive, but in 30 years we have never used a 4x4 to launch any of our boats and never had a problem but then we always did the following.......
Visually inspect the ramp BEFORE you even line up to back into the water, you need to know where it ends and where the sides drop off at. You also need to know if it is covered in algae, if it is then beware that it is going to be slick.
Make sure the tow vehicle runs properly and you are very proficient at driving it, I have seen far to many people that can't properly use a manual tranny constantly stalling it on the ramp, next they become frustrated and do something stupid ..........alas they have successfully launched their tow vehicle as well as the boat.
Don't be afraid to carry wheel chocks with you just in case, this will in no way effect your man status among avid boaters, many boating purists will actually applaud your preparedness and appreciate it. They will tolerate an extra 30 seconds of ramp time in exchange for knowing that the ramp won't be closed for the afternoon while waiting for a recovery vehicle to fish out a tow vehicle.
Brewman61
Ensign
Bingo- give the man a ceegar.
There is no IQ test required to own or operate a boat. Not that it's rocket science, but still................
Public boat ramps are probably the best source of cheap entertainment on the planet. All you need is a lawn chair, a cooler full of your favorite beverages and snacks, and a way to record video. Sit down on a typical busy weekend and enjoy da show.
Heck, bring some basic tools, a battery jump box, a few gallons of gas and some oil, and a 4X4 with a nice strong winch, and you might make enough money to pay for your beer and snacks!
sasto
Years ago I would launch an 18'er solo with a 1967 Ford, 3 speed on the tree, and crap for a parking break. One handed, other in a cast, I would back the trailer in, cut the wheel, and ease my back bumper to a piling to keep her from creaping down the ramp.
Some thought I was crazy, that's beside the point, I just wanted to go fishing. :)
bowman316
when i launched with my stick shift ranger, I would smell clutch fluid burning every time i started back up the ramp.
you just kinda had to burn the clutch a little to prevent rolling back too far.
jeeperman
You would burn clutch fluid?
No fluid should be on the clutch.
Sometimes too I think people get excited or flustered in the launch or load process and get into a hurry.
Then they forget to set the break or put it into park, etc. before jumping out of the tow.
dlngr
Every time I back mine in,I see blinker fluid in the water.
bowman316
i don't know if it is the fluid i'm smelling. but you know the smell of a clutch burning up if you smell it.
NYBo
It's the clutch lining you're smelling, not the fluid.
scoutabout
Launched hundreds of times with a manual tranny. That's a familiar smell alright. Was never sure which method caused less damage. Slipping the clutch or seriously bogging the motor. Neither is too appealing.
Awhile back someone posted a nifty idea about using chocks that were actually tied to his bumper hitch with a couple feet of rope. When you're ready to pull out you just take off and the chocks get drug up the ramp with you till you can pull over somewhere and untie them.
Might do this with my old tractor. Sixty year-old, iffy, mechanical brakes on the rear wheels only do not inspire much confidence. Good thing the local ramp has the slope about like a beach...
sublauxation
Had a brake cylinder blow up once while backing down a ramp....rolled down the hill in a hurry, hit the emergency brake which didn't help much and stopped with what probably looked like the worlds largest "tranny drop."
So as far as how it happens, it happens quickly!
PBJT
a lot of the problems I have seen is too much boat and a 2wd truck. or just a 2wd if you get it in too deep.
Sixmark
If you have too much boat it doesnt make a difference if you have 2wd or 4.
Home Cookin'
most of the problems, other than run-aways, is people sinking their trailers too deep--and the car with it. Traditonally, in salt water, the trailer axle stays dry and the winch does the work. Far fewer car dunkings that way--and less exposure to slick ramp issues. Today, with the popularity of "float-on's/drive-on's" and the alleged waterproof parts (ha!), more boaters are venturing to the unknown parts of the ramp....
bowman316
now that is funny. imagine if you died that way.
"And he died loading his jet ski in the back of his van."
I would stop the van at the waters edge, then make a wooden ramp to get the ski in the van with a winch.
dan t.
Now thats what you call The Nut Behind The Wheel, guarentee he has a rear diff and a trans full of water:eek:
