truck classification
gonefishie
I've never been able to figured out why trucks are classified as 1/2; 3/4 or 1 ton and so on. Can someone explains to me what exactly make them said a 1/2 ton? I know it can't be the weight of the truck :confused:
KM2
Re: truck classification
I'm going to take a stab at this, years ago 1/2 ton, 1 ton etc... that was the load capacity of the bed. The terminology stuck over the years.
craze1cars
Yep. It's a crude reference to payload capacity. Doesn't usually hold very true anymore.
gonefishie
Got ya! that what I kinda thought but like craze1cars said it's not very true so I thought it gotta be something else.
fondafj
Hmmmm -- that isn't what I told my wife when we were shopping for a truck. 1/2 ton was 1/2 the truck "we" needed to tow the boat, 3/4 ton was closer but sill a partial solution... 1 ton --- yep that's the "1" !!!
Actually that nomenclature still does apply. Check any of the web sites and you will find that the load capacity (not towing capacity) relate fairly closesly to the "1500", "2500", and "3500" designations. Here are numbers for a full size Dodge 1500 and 2500 series.<br /><br />1500 = 1400 - 1490 pounds (called 1/2 ton but more like a "heavy half")<br />2500 = 2170 - 2210 pounds (called a 3/4 ton but actually a 1-ton)<br /><br />Load ratings depend to a large extent on the tires, springs, engine, and axle ratio selections.
jtexas
Something to do with the driver's ego?<br />Is it the butt capacity of the front seats?
ndemge
My 3/4 ton Ford, GVWR is like 8800, weighs in at around 4klbs<br /><br />Just know that I wouldn't pull that big ole gooseneck with a 1/2 ton, and I'd rather have a 1ton.<br /><br />The difference between a lot of 3/4 ton and 1 ton trucks?....a lot of springs.
You underestimate the weight of your F250. The lightest version is 5600 and the heaviest is 6600#. The base model payload is 3200# and is 3000 on the 158" WB model. These are 4x4s. GVWR-payload=vehicle weight. Check the Ford web site. Every manufacturer lists this info.
Bob_VT
I can tell you that a 1/2 ton toyota is no where near what it is rated.<br /><br />I hunt with 2 guys who drive toyotas a tacoma and the tundra .... once we load one single 4 wheeler atv in the(625 lbs) bed they tend to squat and bottom out. It was very surprising how bad they are compared to chevy 1/2 tons and the ford 1/2 tons. They may look pretty and have all the newest "technology" but they are garbage for hauling.<br /><br />I laugh at the false advertising commercials I see when they load the toyota.
JRJ
3/4 tn and above have a heaver axel. Look behind the rear hub cap on a 1/2 tn and compare with a 3/4.
Navigator
A lot of times, the 1 tons ride the same as the 3/4 tons. They have extra springs that sit above the standard springs and only come in contact when the bed is loaded and the springs are compressed.<br /><br />Technically, the 1 ton ratings are not all that accurate. I have an 06 Dodge 3500 (1 ton) dually. I can hold 4770 lbs in the bed, thus making it a 2 1/4 ton truck. The same 3500 with single rear wheels can only hold 2820. 3/4 and 1 tons use 8 or 9 bolt rims instead of the 5 bolt found on lighter trucks. <br /><br />Also important is the safety factor. 3/4 and 1 tons have larger brake assemblies designed to stop the loads thay are rated to pull. A lot of half tons claim to be able to pull 9k plus pounds, but their brakes are not designed with that in mind. if a 3/4 and a 1/2 ton, each with the same trailer, slam on the brakes, the 3/4 will have a much shorter stopping distance.<br /><br />Bottom line, the half tons are light duty trucks on lighter weight frames with lighter weight suspension and drive train componants. They have a smoother sometimes carlike ride. The 3/4 and 1 tons are a medium duty pickup. They have heavier frames, stiffer frames and typically stronger engines. The ride will be stiff and jittery when unloaded but they can pull like the beast. You can get the Diesel engines on the 3/4 and 1 tons. They are not available on the 1/2 tons.<br /><br />Price wise, the jump in price from 1/2 to 3/4 is usually around 4-5k. The price jump from a 3/4 to 1 ton is only about 1k. Most people get the 3/4 ton only to realize they should have got the 1 ton. The ride is the same on both.<br /><br />Whats best for you depends on how you plan to use it? <br />Good gas mileage, light hauling = go with a compact truck<br />More room, light occasional hauling = full size half ton.<br />Medium Hauling, Heavy pulling = 3/4 ton<br />Heavy hauling, heavy pulling = 1 ton (fifth wheels)<br />Extreme hauling and pulling = go to the medium duty commercial truck market, example the Ford F450, 550, 650 and 750. There is an entire market that handles this class.<br /><br />Nav :cool:
fondafj
Like Nav said --- there is a significant difference between the 1/2 and 3/4 ton truck running gear. I would add this though--- for snow plowing a 3/4 ton is minimum.
Navigator
You drop a snow plow an a 1/2 ton and it will look like a homeboy lowrider. The front suspension cant hold the weight and it will most probably damage some componants. The 3/4 and 1 tons can be ordered with the snow plow prep package, which adds additional springs to the front to compensate for the weight and geometry of the snow plow.<br /><br />Nav :cool:
