ct1762@gmail.com
Ensign
- Jan 17, 2019
- 958
a bad hub = slippage= alot more RPM than 2k at WOT! This will do nothing in my opinion. Disconnect the tan temp sensor at the pack on both sides and retest. Just be 110% sure its not overheating. If the motor now gets up to full power, its the pack most likely. The only way to know for sure is to run through a complete ignition check via service manual steps and a DVA adapter. Really simple stuff. The temp sender and overheat alarm are directly related to SLOW in the pack as if its hot enough (205f or so) to send the pack into SLOW, its hot enough to set off the steady alarm. 3 beeps as menioned is a fuel restriction. check tank pickup, fuel filter, hose connections w. soapy water under pressure. In my experience a bad fuel pump would cause the motor to stumble the second you give it throttle, not at high RPM.Just a quick update -
Over the winter I spoke to a few knowledgeable boat guys and the first thing all of them mentioned was the prop hub.
Boat came with a Raker 14.5 x 24p. I sourced a Piranha prop 14.5 x 23p for cheap, will be launching the boat next week for the first time this season. Let's see how she goes.
Also did the impeller/water pump kit. Original housing was badly grooved, impeller was stiff but not too bad.
Also noticed that the spark plugs were not the recommended ones (QL77JC4). Replaced with the recommended (QL78YC). Does anyone think the plugs could have been part of my problem?
