Lou C
- Nov 10, 2002
- 13,875
Agree with all of the above and what really helps is to use an outdrive jack and get the bell housing and drive on the same plane with each other. You need to be able to hold the driveshaft as straight as possible as you guide the driveshaft into the bellows and then into the gimble bearing. Also lining the gimble bearing up with the alignment tool is necessary as well. On my Cobra I have also used a long thin screwdriver thru the u joints to turn the driveshaft so the splines line up with those in the coupler.
