Well that really depends on which part you are looking for. If it is a part for the engine power head then any of them would work. However if it is for a part in the drive shaft or the housing for that mid section, then the length could be an issue. Other then that, most parts are used between the models... Parts like carb kits and such are probably universal between the three models. I am not certain on the different letter meanings, but I would suspect that XL model is for a long shaft engine, the E probably for an electric start version and the M for a manual start...IDK :noidea: What you can do is when you need a specific part, look at all three models for that part and see if there are different part numbers. If there are different part numbers, look to see which model closely supports your engine and buy that part. Also, buy a factory specific manufacturer, model, year, HP specific shop manual and it will clear up a lot of confusion between the models. But don't buy an after market manual, it is too general and not going to go into specifics for your engine. The factory shop manuals are the "gospel"... JMHO!
