Trouble finding parts.
Ambern109
I have a 1978 Johnson 115 model number 115ETL78C. Everytime I go to look for replacement parts, that model number isn't there. There is sometimes a 115ETZ78C, 115ML78C, 115TXL78C to choose from. Which one would be the closest one to get parts for mine?
gm280
Well that really depends on which part you are looking for. If it is a part for the engine power head then any of them would work. However if it is for a part in the drive shaft or the housing for that mid section, then the length could be an issue. Other then that, most parts are used between the models... Parts like carb kits and such are probably universal between the three models. I am not certain on the different letter meanings, but I would suspect that XL model is for a long shaft engine, the E probably for an electric start version and the M for a manual start...IDK :noidea: What you can do is when you need a specific part, look at all three models for that part and see if there are different part numbers. If there are different part numbers, look to see which model closely supports your engine and buy that part. Also, buy a factory specific manufacturer, model, year, HP specific shop manual and it will clear up a lot of confusion between the models. But don't buy an after market manual, it is too general and not going to go into specifics for your engine. The factory shop manuals are the "gospel"... JMHO!
Ambern109
Thanks gm280! We were looking for a carb rebuild kit. Didn't see the model number listed and since we are new to all this I wanted to make sure we got the correct one. We also have a Seloc manual it's for a Johnson/evinrude motors from 73-91. Which ours is a 78. Is that a good manual?
Vic.S
I think 115ETZ78 is not a valid number. I think it is a misprint and should read 115ETL78
gm280
Ambern, seems the same carb kit part number fits any of the three model numbers for that year. That carb kits number is 0383906. So see if you can find that kit and rebuild yours. In fact check here on iboats for one. As for the fuel pump, remove the hose from the inlet to the carb and see first if the fuel flows well when the engine is cranked, and it if does I thinking a 3 - 5 PSI pressure would be the usual pressure from that setup. I could be wrong on that and if so somebody correct me... To actually test that pressure, you can buy a little cheap fuel pressure gauge and connect it up to the hose going to the inlet of the carb and read it... Not really hard to do... JMHO!
Oh I almost forgot, the manual I am talking about is a factory year specific HP and model number specific shop manual. The Selco manuals try to cover too many models and years and in doing so they leave a ton of good info out. Buy the factory one and you will see the huge difference...
Ambern109
I'm not sure. I can find the model number with the "Z" but nothing for the "L". Just strange.
