Trouble finding correct thermostat kit for 1996 90 HP Evinrude
SXIPro
1996 90 HP Evinrude Model E90TLEDA. I can not for the life of me find the correct Thermostat kit. Wherever I look, the date ranges go from 1983-1995 and then jump to 2004-2005. The thermostats themselves are Sierra 18-3543, the closest kit I can find is Sierra 18-3673, however it does not show this kit for the 1996 model year, in fact it shows no listing for a kit whatsoever for 1996.
Anyone know how I can find the right kit?
Thanks!
hidef
Re: Trouble finding correct thermostat kit for 1996 90 HP Evinrude
The kit for 1995 90 will work on your outboard. If you do a comparison you will see that the parts are the same between the two years.
SXIPro
It appears everything BUT the thermstats are the same. 96 uses 0434841 and 95 uses 0393659. I wonder if iboats or wholesale marine would mix and match a kit for me? Because if you buy everything separately, you pretty much pay double what a kit costs.
SXIPro
Upon further research, this kit did indeed fit and has corrected my issue. Thank you.
