Trolling motor wiring!
anthonyrivera251
Just bought a new trolling motor and has a boat with internal wiring which i had to replace the old trolling motor plug. I have a minn kota endura c2 55lb thrust motor. What gauge wire should i use to connect the tolling motor to the plug. and from the plug to the fuse panel.
colbyt
Master Chief Petty Officer
Re: Trolling motor wiring!
Probably bigger than you think. A C-30 pulls 30 amps on high speed and 30 amps takes a #10 wire.
NYBo
Welcome to iboats!:cool:
That motor pulls something in the neighborhood of 50 amps at full speed. How long are your wire runs?
Silvertip
Honorary Supreme Mariner
You do not wire a trolling motor to the boats fuse panel. I gets wired directly to the separate deep cycle battery through a 60 amp breaker. A 55# motor draws 46 amps. Depending on the length of the run up and back you may need 6 gauge.
Strikenmike
Pardon the interuption, but for a 45 pound thrust Minn Kota and a 10 foot run to the battery, what size wire should I use.
colbyt
I suspect an 8 gauge if you plan to run it on high. A 10 gauge if you don't. People undersize these all the time. Some get lucky and some don't. I will run 10 for a C-30
