Trolling motor swap
mav6759
Quick question, Does anyone know if you can swap out the lower end of a trolling motor. Let say you have a 40lb thurst and you want to put a put a 60lbs thrust motor on it. can this be done.
Thanks Mav
tashasdaddy
Re: Trolling motor swap
doubt the wiring would be the same size.
Shizzy
Ensign
im not sure why you would want to do this. sounds more expensive and time consuming then just swapping units and selling the old one.
Silvertip
Honorary Supreme Mariner
You realize that the 40# motor is 12 volts and the 60# is probably 24 volts?
zeadog
i have a 1993 motorguid 65lb trolling motor it is a foot pedal control and is in good running condition. i am trying to sell this motor but have no idea what it is worth can anyone help me?
xxturbowesxx
Try Craigslist but this is not the correct place to advertise.
Back on topic just sell your working motor and repurchase a used one.
