Cking96000
Thread starter- Joined
- Oct 1, 2016
- 7
Bought a used trolling motor it ran for 20 mins then wouldn't run anymore. Took it all apart and notice one of the springs where it provides a connection from the handle to the propeller was all messed up and wouldn't spring it back out. (Clueless on motors hence the lack of technical terms) anyways I messed with the spring and then put it back together and it started working again. Obviously I'll have to replace the spring for a permanent fix. Just wanted to make sure that's what the problem actually was and also it seemed very rusty inside. Not on wires but just coated inside. What could I use to clean all that out? And finally for a40lb thrust it doesn't seem like it's pushing that hard. Is there anything that could be preventing it from using its full potential? Thanks in advance. (Included various pics of everything I took apart)
