Trolling motor for pontoon boat
Uncle Doug
I am thinking about getting a trolling motor for the 20 foot pontoon boat I am rebuilding.
My questions are how much thrust, shaft length, mounts, foot control or remote?
tashasdaddy
Re: Trolling motor for pontoon boat
i am using a Motor Guide WP45 it is the the wireless control unit, i can control from anywhere in the boat. i have a 45 inch shaft, they also make a 55 inch.
Jeff-in-PA
click for big pic
I have a 55lb Minn Kota on my 24' Starcraft. It's the biggest 12V offered ( by MK ). I have it slightly offset so the dog can still see out the front when he's laying down.
I also have a depth finder with temp attached to the trolling motor.
Jeff
mike243
i have a 18' suntracker with a 50hp merc,i put a detachable mount plate where the front gate is,i am using a 36lbs & it does a decent job on most lakes.i do have a all alumiunm deck & is fairley lite.a bigger 1 might be better but i mostley slow troll out on the lakes or move short distances.a river would require a lot more thrust & batterys ,i will be running all day with 2 batterys here shortley,if it ever quits raining,mike243
MinnKota 55PD V2 on mine. Works fine. Quick release plate as we travel alot and I move it inside so the travel cover doesn't develop wear spots.
Pontuned
I have a bass buggy with the same detachable plate setup. I am using a 55#, 52 inch shaft Minn Kota hand control. It moves the boat well and I am satisfied with it although I will probably trade it out for a foot unit in the future.
mike243
i normaly keep the shaft set tite & steer the boat with my steering wheel,no sharp turns but when your trolling you dont need to turn tite or you will drag the bottom & hang up if your not in deep water,mike243
