Re: Triumph Boats? Good or Not?
I have a 2001 210 CC (Logic/ Triumph)with a 130 Honda. A great fishing boat.. I fish in the ocean and bay navigating Barnegat Inlet ( quite snotty at times). I feel the boat may be a little light in the bow, this might be due to the weight of the engine (almost 500 lbs) and a large fuel tank (85 gallons). I do have an issue with the hatch lids not sealing and water accumulating in them. Ther is no thru hull drain, there are plugs. I either pump them out or pull the plugs while underway and replace them as soon as they are empty. I will do something about the non-sealing lid gaskets this spring. The metal is stainless with no corrosion issues. I only give it a quick wipe with aluma-guard and I am good to go. Top speed is low 30s w/2 or 3 aboard. Maintenance is a snap. No problems with the bunk trailer.The ropolene hull is a pleasure,little pounding and the flexing is unnoticeable. I have bounced it off docks, rocks and sand bars with NO damage at all! The price is right, I would do it again. A boat rental outfit in the area features them and loves the durability and lack of maintenance. I touch up my hull with Micron in the spring and go fishing. No waxing or worrys about gouges in the gel- coat.
