Trim
Maverickfe
To remove the out drive on the back of the motor and all the screws in the picture?
No.... see post 15
see the vids if you dont get a factory manual
pull the esa cover, disconnect the shift cable, fish the lower shift cable out the back, remove the trunion caps and pull the drive
to pull your motor, you would pull the screws in the transom, take the transom ring off and push the boot thru to the inside and then take the motor and intermediate out as a whole unit.
Maverickfe
Well i got it loosen but the cable is holding me up any thoughs?
There should be a clip holding the cable under the intermediate near the ball gears
Dont damage that cable, its 3/4 of a B.O.A.T. unit
Maverickfe
Just want to say thank you for the help Scott just to let you know my name is Scott to lol
