trim will go down but not up
stonyloam
Re: trim will go down but not up
I meant intimidated
you should be LOL. That job is a major PITA. Assuming your bravo is lika an alpha, it involves removing your bellhousing, so I would suggest that you study the job really well before starting, and plan on replacing the bellows (driveshaft and shift cable) when you do it. For now jumper those connections and just be careful how high you trim the drive when you are running. Do your research and good luck.
tpenfield
I replaced the trim sender and limit switch on my Bravo 1 drive without removing anything. It was tricky, but saved from dis-assembling the bell housing stuff.
panamacitymustang
how did you replace them without removing the outdrive
panamacitymustang
I just want to say thank you to everyone for pointing me in the right direction
