trim/tilt pump
lawn
Hello fella boaters. I have a 1976, 135 evinrude with a calco trim/tilt. I would like to find the schmatics on the pump. It has been apart several times and it won't let the manual release screw let the engine down nor will it trim out under power. Pump has excellent psi. When not under power all works as should be..Can you help.
