trim tab ?
martin47
my outboard is a 115hp mercury.. the trim tab is damaged.( only just found out what it was called ) what is it for, and how simple is it to replace . thanks .
rickdb1boat
Re: trim tab ?
One bolt from the bottom holds it on. The trim tab can be adjusted either to the right or left in increments to help straighten out steering pull when underway. The trailing edge is moved in the direction of pull..
Scaaty
Re: trim tab ?
I pretty sure (is on mine anyway) the bolt is under a rubber cap at the very rear looking down. It screws into the anode/fin. If the cap is gone, don't worry about that either..just cosmetic
martin47
Re: trim tab ?
thanks helpful as ever,,,, for us beginers this forum has proved to be the best ,,,,,, we would be lost with out you ... i would be any way :)
