parttime
Thread starter- Joined
- Sep 7, 2008
- 4
ok, I posted about 1 week ago about the trim system on my 78 johnson 150. I've recently picked up a manual and hung the engine back on the boat and actually gotten the trim system bled out to the point that its working quite well. now the task at hand is wiring everything back together. when I received the boat I had three wires coming out of the trim motor laying on the back of the boat and three wires coming from the handle/switch assembly. there were sliced wires and bad splices throughout but neither piece was connected to anything. the wiring diagram in the manual that I purchased shows some type of bar or bus or connector strip or something and a solenoid. I need to know where these pieces are or should be. thanks in advance for any help. if it helps, the boat is a 1982 ranger with a 1978 johnson seahorse 150.
