trim sending unit
Robhoov
When I was working on the transom recently I accidently damaged the trim sender tryig to clean it. It appears that the the circuit path on the stator (disk the contacts ride on) is damaged so it won't indicate a smooth reading on my dash guage. The more I messed with it the worse it got. Does anyone know where I could pickup a good used trim sender w/o having to buy both trim sender and limit contol kit for @ 80-100$ I just need to replace the stator.
muc
"Retired" Association of Marine Technicians...
Re: trim sending unit
P/t sender rotor kit 805134a 4 $18.05
Robhoov
Thanks so much, I picked up the rotor kit for about 18$ saved at least 60$ not buying the sender/limit kit.
ceferron
I just started looking into an issue with my trim indicator not working, ie it always says up. I suspect the Trim indicator, would this kit fix my trim indicator as well, or am I better off buying the full kit?
And to say I am new to boats is an understatement so thanks for the help in advanced.
