diggindeep
- Nov 10, 2010
- 3
I have 1999 twin Evinrude 150 Ficht motors on my CC. The trim on the port side motor would only work in the down position and not up. I have checked all of the connections and relays and they are fine. I bypassed the entire relay box with a jumper wire straight from the battery to the 2 wire plug that goes to the trim pump and it works up and down, eliminating a pump problem. I removed the relay housing and relays from the starboard side motor, that was working fine, and installed it on the port side motor and it still will not go up. Any ideas?
