trim problem
yfzjim
I have alpha one drive with two switches for the trim one says trim other says trailer. the trim button works to go down but not up and the trailer button works up but not down. are my senders bad you think?
dubs283
Re: trim problem
the trim limit switch located on the PORT side of the bell housing is either not set properly or broken
does the trim gauge on the dash work properly?
the trim button will move the drive all the way down, and will trim the drive up through the trim range (about 1/4 up)
the trailer button is used to tilt the drive beyond the trim range up for trailering
download manual #6 from the adults only sticky and look at the trim system info
yfzjim
Re: trim problem
there is no trim gauge. Ill check out manual #6. Thanks
