Trim problem, went up after launch now cant get it down
sfestiva
Guys,
WHile on trailer on boat ramp, lowered the trim/lower unit, turned on the motor (mercruiser 3.0) backed up, then noticed the outdrive is up. While in water couldnt get it down (using the trim button), so put her back on trailer and off back home.
Now while in garage, added oil to pump (was low) the trim pump runs when I press the down but the lower unit doesnt move.
Bled the hoses, still doesnt come down.
Hints?Ideas?
Fishermark
Re: Trim problem, went up after launch now cant get it down
It may sound odd, but have someone, (a large friend preferably ;) ), stand on the outdrive while you press the down button. Jump up and down a little if necessary. See if that "unsticks" it.
Guys,
Hints?Ideas?
Ayuh,.... When ya run it Up, ya know how it labors at the end,..??
Tap the Down button a couple times to relieve the over-load condition...
sfestiva
Thank you guys for quick response!!
I tried to stand on the lower unit and give it a few jumps while my wife press the down button, but nothing happened :(
Why would the drive while on the trailer on the boat ramp after I lowered it and reversed the drive went up? Isnt supposed to lock down? After I put it back on the trailer I noticed the trim pump reservoir low, so filled it in but that didnt help get the drive down.
Do I need to unscrew the hydraulics (both up and down) for both rams and see if it goes down?
Don S
What year, what pump?
sfestiva
Looks like it was replaced in 2010
I suspect this is oildyne?
fat fanny
Is the motor running while trying to lower it? More diagnostics are required on your part do you have a service manual? if not look in the stickies for the manual for your drive. It would also be a good idea to tell us what your working on year,make and model. Or you could call Jerry and ask him why theres a bunji cord wrapped around your trim pump!!!!
sfestiva
lol at bungie cord... thats what I said when I saw it before I bought it back in august.
Anyways, the pump is working. I am pressing the down and the pump is running but sounds like it is straining. To me it looks like the rams both or either one is stuck?
How do I check the rams?
dingdongs
more than likely an air pocket has jammed the check valve.crack the pipes on the back of the drive to release a little pressure.get some one to trim down a little whilst you may be standing on drive.when it starts moving retighten pipework.go up and down a number of times and this should self bleed.keep an eye on the levels at all times.once your happy with the running the drive when your trimmed up would appreciate a nudge on the button down and this will always help the pressure side of pump.when bleeding make sure all is running smoothe as there should be no sticking at all.
Ayuh,.... Pull the aft attachment pin, disconnect the oil lines, 'n you should be able to push, 'n pull the rams, in, 'n out...
If ya boat in Saltwater, they tend to corrode, 'n bind at the gland nut, against the ram...
26aftcab454
I had the same thing happen to me last month. The low pressure Reverse Lockout line had come loose. I just replaced the compresion seal at the fitting, filled with oil, and am back in buissness . pump.jpgpump2.jpg
sfestiva
Update:
thanks all for tips, extremely helpful!!
I removed both trim cylinders, and there is no way they can move freely in and out. Even by using a hammer, I couldnt get them to slide in and out. Looks like I need new ones..Also noticed one of the high pressure lines is corroded at the end.
Are the SEI rams good?
fat fanny
If the cylinders are disconnected from the system I would start working them to free them up and checking the input and output ports for blockage what do you have to loose!
sfestiva
Update:
Got new SEI rams! Went ahead and installed, however the low pressure compression fitting on one of the rams is leaking at the fitting, tried to tighten but still drip.
Question, do I need to use loctite or other on the threads? if yes what kind?
dingdongs
replace fitting and dont mess the new rams up with a faulty pipe.do not use loctite or any other product.
