Trim not working properly
Burton159
I just bought a 1996 Stingray 609 with 4.3lx mercruiser and Alpha one out drive. The outdrive goes up and down at switch at the back of the boat. A the remote it will trim down but not up unless the boat is in the water? Is this normal?
tpenfield
There should also be a switch (or switches) at the helm.
The way the trim system works is that there is 'trim' and there is 'tilt'. Theses are typically done by two separate switches. The trim switch will only raise the outdrive to the "Trim Limit", which is the highest point in which you can safely run the propeller. The 'Tilt' switch by-passes the 'limit' function and will raise the outdrive as much as you want until it reaches its highest point.
Boats are stupid and they don't know if they are in the water or not. It sounds like the switch at the transom (rear of the boat) is only a trim switch (???) unless it has both a trim and tilt button.
Alpha Drives can have the trim limit switch in the up/down pivot point of the outdrive. The trim limit switch can be open to the water and can rot out. One of the pivots points is the trim gauge sender, the other is the trim limit switch.
