Trim motor stuck running up.
Misterbegnoche
Don’t know what’s going on!!! I was cleaning my boat and noticed I bumped the throttle handle forward so I put it back in the upright position. A second later my trim started going up and wouldn’t stop and next thing you know at ground wire by the lower end of out board smoked up. I reacted very fast removed battery terminal. I go to put main battery line back on it’s fine. I use trim switch on Suzuki outboard the switch is fine. I go to hook hot from bus bar back on battery and the trim motor does the same thing. So scary when it smoked up. Good thing I was out just shop vacuuming the carpet at home. If anyone could help with some advice that be awesome.
