Trim limit switch not working - 1994 Mercruiser 3.0L Alpha One
pinkt
Hello,
I recently replaced my up solenoid because the control switches were not working. Now it works good, but I seem to have lost the up limit on the trim. In other words, the out-drive will go all the way up to trailer position with the trim button. I did take the outer cover off the the limit switch to clean the contacts, but that doesn't seem like it should effect the adjustment. Also I had unplugged and re-plugged all wires around the control box to check for loose connections. I did that one at a time to avoid mix ups. Any thoughts on what might be wrong? I appreciate your help.
tpenfield
I'd re-visit what you did to the limit switch on the outdrive
