Trim Lifting Motor Very Slowly
nmelche
1987 SeaRay Sorrento. Trim works perfectly dropping the motor but is very slow to come back up. Currently have the outdrive off and the rams are still moving very slowly out. Disconnected the up lines and ran the pump. Hardly any fluid is coming out. Any ideas? The attached photo is what my pump looks like. Thanks!
alldodge
If this just started, its probably a pressure issue. Something inside the pump is not allowing the pressure to build correctly. Up should have more pressure then down
nmelche
Ended up taking he whole pump apart yesterday and the fluid had some clumps in it in the reservoir. Cleaned everything out and it works much better now!
mike_i
That's good news you found the problem, clumps are no good.
ended up taking he whole pump apart yesterday and the fluid had some clumps in it in the reservoir. Cleaned everything out and it works much better now!
