Trim gauge/sending unit.
firstinfireman
5.7 mercruiser with alpha 1 out drive. Trim gauge shows all the way up or all the way down. Adjustment or sendin unit replacement?
Bt Doctur
Re: Trim gauge/sending unit.
most likely replacement , the wire wound resistor is damaged in the sender.
achris
More fish than mountain goat
Depends. Has it worked in the past, and has just stopped working (or someone has been working on them) or has it always been like that?
firstinfireman
I just bought the boat. That is the only gauge that doesn't work properly. I usually trim by what feels right. But if it just needs adjustment I'll mess with it
agallant80
I would not worry about it. There are lots of people who trim by feel and sound. I have one and its off but I just ignore it.
alldodge
Most don't use the gauge, just trim by feel even if it works. Start with adjusting the sender first, it's on the starboard side. Probably need an impact screw drive to break it loose. If it bounces quick up and down quickly the sender is bad.
