trim button issue
weekender1
well have been spending time out on the lake she runs very well after fixing a slight leak i just found. but have a question about the 3 button trim switch. the in button works fine and the up/in+up button works when both are pushed,but when i push just the up button nothing happen?? i did try to adjust the trim limit switch on the port side but nothing happens when i turn it. any ideas?? the boat is the 80 arrowglass tri hull with a 165hp. the motor and the trim motor are out of a different boat
a side note the trim pump that is out of another boat i still have the one from the arrow. and also there was like a cylinder type of pump above on the transom still have that also.. .
dubs283
either the trim limit switch is out of adjustment, broken, or the wires are not correctly connected
