trim and tilt does not go up.
123bigfrank123
Greetings, I have a 1992 225 hp evinrude which does not trim or tilt up. i have switch the relays up. it goes down just fine.
RRitt
Re: trim and tilt does not go up.
Check for a shorted trim limit sensor. check wiring into relays to confirm that your "up" control voltage is being delivered. Hot wire trim motor to confirm working motor. It should be one or the other.
mandyb52
is it up or down??? sometimes the saftey levers on tilt go into lock
123bigfrank123
Greeting RRitt, I was on my boat this morning and I realized I do not have voltage going in to the relay. motor works fine when i hot wired it. Where is the trim limit sensor located at?
123bigfrank123
ezeke
It's a switch, located on the stern bracket, above the PT&T unit. If it sticks open the unit won't work.
123bigfrank123
thank you guys, that was the problem. i jumped the switch by tracing the cables. i notice there were two connectors. i unplug them both and connect them straight to the relays. it works perfect. thanks again.
