FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
i have a 84 Johnson 115 hp.... I'm having inconsistent spark so I decided to test the trigger... I got 14v + on one side and 4 to 5 on the outher side..... Does that sound ok?? or not so good??
Normal cranking volts on a special "peak reading" voltmeter for the timer base are not that high. Depending on year, there are two values, one in the 0.3 volt range, the other in the 0.6 volt range. The CDI specs for your year will be specific.
