twintrades
- May 7, 2008
- 305
OK so i still have yet to makeshure the motor works but i have a...
1987 OMC DELUXE inboard, Looks cool. Anywho it has a couple of scuffed up spots on the Leading edges of the tri hull. ONe has been patched before they used poly resin directly over the gelcoat. ( kinda just cut a patch and slaped er on there.) I was thinking about taking that one off and seeing how bad it is i doubt its verry bad.
The boat when made was totaly filled with foam underneeth. They claimed you could pull the plug when out on the lake and it would not sink. You just plug it back up and hit the bilge pumps and away you go.
I thought oh crap how do fix the hull sections without applying a backer to them ?? ( ive been watching the West System tutorials on youtube.) So how would you fix it?
So now hears my question's
1 Can i use bondoGlass if its not too bad? (holes dont go all the way through.) Will it hold up?
2 If i have to use fiberglass Is it hard to layup outside corners?
3 When it gets repaird Could i use white rustoleum ? Or do i have to use marine paint ? ( Poor man talking)
Thanks
Thanks
