Transom wood recommendation
Qrzed
Have gotten a lot of opinions on this so I figured asked the experts. Got the old transom out in one piece not to bad of a job. Now what is the best replacement wood to use for the new transom? Thanks for your help
Woodonglass
Honorary Supreme Mariner
Since you stated it came out in one piece, I'm going to assume this is an Aluminum boat. There's a brand call Arauco that's excellent, Also any plywood that's rated "Underlayment" is also good for transoms. Just make sure to Seal the edges and fill any voids to inhibit water penetration to the inner layers. Epoxy is the best resin to use for sealing plywood but there are several other good viable options.
