Hi folks!
Need a little help here. Im in the process of redoing my transom and ran into a problem while taping the seams. For some reason I cannot get the biaxial tape to lay down correctly and hopefully someone has a solution
I got the bottom seam to lay down just fine. I tried different ways and its just not working at all, first time I ran a thick bead of fillet along the sides of the core left and right then tried to lay the glass over that but that didnt work, so i had to pull that wet glass back off and smoothed out the fillet I made. The second time I used a router with a 3/8" roundover bit and rounded the edges, this worked alot better but i still have a few air pockets from the glass not laying over the edges, Heres a few pics of what I have done so far.
You can kinda see some of the air pockets on the left and right sides of the transom. How to go about fixing the air pockets? Do I not worry about it and add my second layer of tape? Whats the best way to get this stuff to lay down correctly cuss this is frustrating and cant afford to be throwing good tape away due to it not laying down correctly. that white stuff on the bottom seam is just dust if anyone notices that, kinda looks like the glass is not layed
So, that is my dilemma and really need some quick input on this issue, any help/advice would be great and thanks for reading.
Tigers131
Tigers131
