bear_69cuda
- Oct 10, 2008
- 2,109
Hey gang,
I asked Hurricane about adding a hydraulic jack plate on my boat for various reasons,
Below is the response I received from Nautic Global Group. Currently I'm running a Yamaha F150TXR, and my hull is rated for 200 HP. The Yamaha F200TXR is 117 lbs more than the F150, and 50 more HP.
Does anyone think a 6" offset hydraulic jackplate will stress the transom as much as the max HP and weight rating, or cause it to fail? And if so, could it be reinforced?
Hi Bryan:
Hope all is well with you and your family.
While we are aware that some people have used jack plates on our boats in the past (mostly manual), we cannot recommend their use. The use of a jack plate will add extra torque and strain to the transom which we have never measured and tested and therefore do not recommend their use. We are not saying that an issue would arise, but without thorough testing, it would be a concern and if an issue were to occur that could be construed as resulting from the use of the jack plate, the warranty on the transom would be voided.
Sorry it's not the answer you were hoping for, but better safe than sorry.
Clint
Hi Bryan:
Clint
