Transom saver...gas strut or spring loaded?
richg99
When I bought my boat, it came with a standard transom saver. Seems to me that the TS transmits all of the road shocks right to the boat's transom. Is there a gas strut or spring loaded transom saver that will absorb some of the shocks? thanks Rich
Huron Angler
Re: Transom saver...gas strut or spring loaded?
A transom saver isn't supposed to move.
It's designed to hold the lower unit in a fixed angle so it isn't flopping up and down, saving the transom from the stress of the bouncing.
Hence the name. Don't throw it out, you could at least give it to someone who could use it or sell it.
Huron Angler
Here's a photo of my transom saver. You might have a different one so I wanted to clarify. It attaches to the trailer and the OB rests on the other end to prevent it from bouncing.
F14CRAZY
Ensign
But a transom even with an OB shouldn't move at all...
richg99
I never said I was going to throw it out. ???
Thanks for the LINK to the Cabela's product. It seemed to be what I had in mind, though I wonder how the springs would hold up in the salt water environment that I live in.
Unfortunately, out of three reviews...two were very negative. I'll just keep what I have and hope it works out. Thank you. rich
smokeonthewater
The "don't throw it out" comment was aimed at me...... I suggested that you do..... transom savers are generally NOT needed to protect the transom.... If the transom of a boat is going to be damaged by trailering then there is no way it will hold up to use in the water.... the outboard will put 10 times more stress on the transom in operation that is ever does on the road.....
On the flip side running the one you have won't hurt either and if it makes you feel better using it then you're good to go...... happy boating:)
Reel Kahuna
...the outboard will put 10 times more stress on the transom in operation that is ever does on the road.....
Apparently you haven't seen CA roads lately. Driving over them will knock the fillings out your teeth :p .
moonfish
When the boat moves, the outboard needs to move the same or there will be strain on the transom. If there's a shock and the outboard can bounce, it's bouncing on the transom and that is stress, imo.
Stachi
I agree...it won't hurt the gelcoat to have a little give instead of a hard shock to the stern when you drive over the inevitable pothole without a transom saver...I am guessing it was invented by a boater for a reason...
mike64
When i first got my boat I relied on the clip that held the OB up. then I read on this forum that was not a good idea, That clip was not really meant for going any distance at all.
The transom saver transfers stress from the raised motor that's being held up by the tilt unit and the transom, to stress shared between the trailer and the transom. Whatever type of transom saver you use, as long as it fits your setup, you won't regret it.
Reel Kahuna
I've seen this type of transom saver that slips over the power tilt piston(s). Anyone using it? Your assessment?
Proselect
[/QUOTE
I would like to know more about this one as well. I have the tilt lock lever on my motor and have been using it. I thought about a transom saver but read all the debate on if they are neede or not. I am interested if this little unit would be the answer. It looks like you can tilt the motor up enough to give you the ground clearance yet still leaving it far enough down to take some of the pressure off the transom. Could you make something like this? A piece of painted pipe perhaps?
Bob_VT
That is not a transom saver..... it may save the lock mechanism but all the weight is still on the transom......
I used them before and intend to on the boat I am re-building just to hold the motor stationary during road trips. The weight of the motor is always on the transom....think about it.
Reel Kahuna
I would like to know more about this one as well. Could you make something like this? A piece of painted pipe perhaps?
The company advertises it as a transom saver. Don't know how well it works so that's why I asked for comments. http://www.m-ywedge.com/
As for making one, I'd recommend going to Taps Plastic and buy a 1-1/2" or 2" diameter round stock Polymeyer (sp). Drill a hole in the center to accommodate the piston diameter. Raise the motor, place Poly over the piston then lower the motor until it rest on the Poly.
Expidia
[/QUOTE
Those piston models suck. I bought the Mywedge brand for like $50 shipped for this little piece of rubber. Cost you twice that if you have two pistons. Can't be good for your piston with all that bouncing around. But his web site vidoes and letters are impressive and it sucked me into it.
Nothing worse than looking in your rearview mirror and seeing your outboard bouncing up and down.
I like the Panther brands cause you can find them at big discounts with a little searching.
This is the model I like now because it has a long reach which twists into the trailers cross member especailly if it sits far under the transom. You just twist the end into a bracket that mounts on the trailer. No need to get down under the boat to bungie both ends with this model. You still want to bungie the end that the leg sits in or it will bounce unless you crank the leg down and then you bust the rubber or bend the v bracket (been there done that).
This is my older model that the end sits on a roller:
The bungies are not shown in the pic below but you need to use them on each end.
That bracket that's on the side of the outboard is to prevent the outboard from coming down on you like when you extend a 4 stroke to change the oil. My Merc manual says don't use it for trailering. You will only bend it and the O/B is still going to bounce up and down. yep, I already bent mine the first season cause the dopey kid who sold me the boat said that bracket was for trailering. It's such a thin bracket that I was able to use a monkey wrench to bend it back!
PWH1
I have been looking for an alternative, thanks for posting this information. I ordered one this evening, hope it works as advertised.
j_martin
I use a "transom saver", mostly for the long haul. I'm not worried about the transom, but if the hydraulics fails on the motor, it'll keep a skeg and a $500 prop off the parts list.
I did have my hitch let go on a really rough asphalt road, and the tongue dug in pretty hard, bending the winch tower. I figure the transom saver, transom tie-downs, and motor hydraulics kept the boat out of my trunk.
my 02
John
Expidia
Tip: I place a washcloth in the V that the leg sits in. Even if it's the style that has the 4 rubber feet both styles will mar up the paint a little from movement. If your outboard is white just use a white washcloth. If the TS has the 4 rubber feet don't let the piston crank it down too much or you will compress the feet up to the rivets that hold the feet on and it will scratch your outboard leg (ask me how I know this).
I'm going to trot down to Walmart and get me new "black" washcloth, so I can trailer in style :D
