Transom rot !!
shaw520
Re: Transom rot !!
Wood is in and glued, allowing cure time. Glass should start tomorrow night.
Yacht Dr.
Re: Transom rot !!
Hello Shaw..
You should consider beveling those sharp edges before you glass... ( woulda made less mess in your work zone if done out of the boat m8.. ).
YD.
shaw520
Re: Transom rot !!
Hello Shaw..
YD.
Beveling the edges will be done before glassing.
'Work Zone' you say? ... good point there Doc, wish I could be in a perfect world,..cept' Im working alone as efficiently as I can, with limited time to complete,..(I have a real job). Working within the boat is saving me tons of time climbing in and out,... besides I have a very good shop-vac
If you look closer you will see that on the port side, the transom rot continues past the inboard stringers, .. so I needed to maneuver the transom section in before attaching stringer & brace sections. Its piece work at best because the rotted sections are isolated.
Genuine Question; Cut key hole now??,.. or glass before cutting?. whats better?
Itsalonestar
Re: Transom rot !!
Very true....angle joints work fine for house trim, but don't want them where strength is a consideration. With the glues being stronger than the wood fibers they're holding together, any type of overlap joint is very strong.
Oops:
Not to be too picky but a lap joint and a scarf joint are different.
A lap joint is where one piece of wood is overlapped by the other. Usually each piece is dadoed in half.
A scarf joint is where they both are cut on an angle and then jointed together. Usually this is done at 45% angle but can vary. Scarf joints will usually used where movement will not expose what is in behind, usually for cosmetic reasons.
Worked in the Shipyards in Ontario growing up......learned a couple things from the shipwrights. Carpentry on boats is the most challenging work of all.
In this case I agree with you that the lap joint would be the better choice. I would also use wooden dowels to pin the joint for some added strength. Not that it would need it as the glass and matt will do a job. Just my finicky way of doing things.
Cheers.
Glenn.
Itsalonestar
Re: Transom rot !!
It's a shame boat builders use materials in critical areas that are destined to fall apart....a sad commentary on the industry in my opinion. Had an old 70's Starcraft tri-hull that got in that shape, and my cure for that was to cut it into 2 foot square sections and let the garbage men haul it away. But for the rotted cross members and transom, it would have lasted for generations. I probably would have gone to the effort to salvage, but I never liked the flopping up and down slappety-slap ride that particular design gives in rough water.
Its a 1980 Thompson Sportmen that Ive owned for nearly 20 yrs, I put a fresh 165 Merc in end of last season and runs great, this season I discovered the transom rot. Vacation planned for Aug 22nd, so I need to get the transom rebuilt, engine and drive back together before then.
Tell me,... why do some of these manufactures neglect to glass the inside transom ????
shaw520
Re: Transom rot !!
All glassed in, next step cut key-hole seal edge, apply paint and reinstall power. Bumped my vacation to 2nd week in Sept, just wouldn't be a vacation without the my tug.
shaw520
Re: Transom rot !!
Next issue Im going to ask for opinions; As mention earlier in this thread, what caused the transom to rot was a series of screw holes that mounted the swim platform (four holes @ four locations across the transom that left several spider cracks in the gelcoat) So, in an effort to to seal the holes/cracks and at the same time give the swim platform/transom more structure.. I thought about glassing over the holes/cracks, and attaching a piece of 5/4" X 8" X 6' teak right over the old holes.. then mount the swim platform to it... like in this awesome drawing I made! ?? Opinions??
  • drwin.pdf
jonesg
Re: Transom rot !!
Instead of screws which work loose from the load and allow water in,
try thru-bolts with backing washers and bed with 5200.
shaw520
Re: Transom rot !!
Ok, I planned on using SS bolts going all the through, but what exactly do mean "bed with 5200" ??
Thank you Shaw
