transom rot
rob orr
ive just dug out the rotton wood from my picton fishing boats transom and need to know if i have to prep the replacement plywood , i was thinking of coating it with resin , if anyone has any suggestions it would be appreciated...... rob
bigredinohio
Re: transom rot
Depends on what you're using and your method but yes, you need to prep your wood.
Basically what I did:
1. Make sure it's dried out (especially treated)
2. Glue 3/4" together wood
3. Cut out shape
4. Coat it twice with resin then on the third coat added fiberglass cloth
5. Glued, tabbed and now finishing up the last layer of fiberglass
bigredinohio
Re: transom rot
