Transom repair
bluefinnn
Seems every post I've read says to cut the 3/4 marine plywood shape out of 2 pieces then glue the two of them together. My transom is 23" by 66". When I bought my wood I had them cut it in half for travel & handling. This maybe a stupid question but couldn't I just cut a couple feet off the length & glue the 2 together & then cut out the transom shape. Are you cutting them separately just for the ease of cutting (3/4 vs 11/2) ?
tpenfield
When you say "cut in half" do you mean 2 24" x 96" pieces or 2 48" x 48" pieces. :noidea:
No rule says that you can't glue the 2 layers together and then cut to the final size & shape.
matt167
Absolutely cut them together. I would not glue them before cutting, but use clamps.. This is the sides of my plywood boat just after cutting. Just use similar clamps close togther and I would recommend the best possible blades you can find for your jigsaw. I use Lennox blades with a fine TPI.
The reason for not pre gluing is the amount of glue you need will be a lot less. You can even coat both pieces in resin before assembly
two reasons to cut to shape prior to glueing
reason #1 - much easier to cut 3/4" vs 1-1/2"
reason #2 (as Matt pointed out), no need to waste glue
I normally glue together, then screw, after glue is dry, remove screws if they are in the way.
Woodonglass
Also, having an EXACT fit is not required nor preferred. You want about 1/2" gap around the perimeter to allow for the PB to ooze out and seal the edges and also make a nice coved fillet.
rookie456
I think I have the same boat as you, 17’ blue fin.
I installed my plywood transom over the weekend and I think it went pretty smooth. I cut my plywood into 2 24x68 pieces, then glued and screwed them together. Let it dry, removed screws. I then traced my template on the plywood. I used a circular saw to cut all straight edges, and a jig saw to cut the 2 curves. The reason I liked glueing and then cutting was that it gave me nice flat edges that matched up to the aluminum edges when I installed it, which will provide a nice surface for the aluminum top cap to attach to. I’m no expert, this is my first transom replacement.
