LiLGrady17
- May 1, 2008
- 67
Not sure if this is the right forum. Since it's not exclusively related to the manufacturer of my O/B, I figured this was the best availalble choice..
I'm in the process of hanging a replacement O/B motor. On the top engine bolts, the PO wound them down really tight, enough to dimple the FG on inside of splash well.. Onr the lower bolts, they were wound very tight as well.. Retrieving the lower bolts from my bilge, they had large clear silicone masses on the heads (you can make out the rings in the pic), but some other sealant in the threads, and some crust salty deposits on the hull side with resin flakes attached. Where the bolt come thru the hull, into the bilge area, the resin & gel have some chips off inside of the hull down to the wood.. Poking into the hull inside the holes, it's hard, no mush. Boat was always trailered with said PO, so I don't think any big damage was done. Transom is solid, no flex or waves. Can I clean up the surface, & use 5200 or epoxy, on a piece of starboard to spread out the load inside the transom, & to seal up these areas missing resin? Then I would drill the starboard, & though bolt everything??? Most of the lines away from the actual holes I can't feel with my fingernail.. Some are dirt & dryed silicone as well..
http://i6.photobucket.com/albums/y243/NYdeer/GWTransom.jpg
