devils choice
- Nov 30, 2013
- 8
Hi All,
First post so hope I do it right ! I am restoring a grp Avenger 21 ex race boat and need some advice please as I think I may have messed up, firstly I glued two 25mm pieces of marine ply together with Epoxy resin and then used the left over epoxy to seal the rest of the transom, once fitted in the boat I was going to tab and glass in matting with polyester resin on the rear of transom but I read on this very informative site that you should not use poly with epoxy is this correct if so should I sand back the ply and start again ??? I will try to attach some pics , thanks in advance.
