Re: Transom plywood
I've done a few Starcraft transoms over the last year now, I've yet to do one in PT for the fear of corrosion from the treatment. I realize that not all PT wood is corrosive, but not being able to tell which is which for sure, I'd just as well avoid it.
I do most using 2 layers of 3/4" ply, the best exterior grade I can find, and I screw and glue them together using stainless screws and sandwich them with epoxy and a layer of fiberglass inbetween. I generally just use several coats of epoxy paint over the finished panel and install. My thinking is that most of these boats are 40+ years old and the transoms have survived this long being plain wood, so anything I do beyond that will outlast me or the boat in most cases. Many of those transoms weren't even painted, my 1962 16' Starcraft's transom was bare marine plywood, and appeared to be single layer 1 1/2" ply. It lasted 43 years and the only part I found rotted was directly around the port side rear tie down eye. A former owner had soaked it with Getrot and it probably could have been left be, but being that these are an easy job and I wanted to properly fill several dozen unused transom holes for good by welding, I chose to replace it the same time I did the floor.
The original wood came out intact and made the perfect template.
I did a small aluminum jon boat transom last week, I didn't have enough resin to laminate with handy and it was only an open jon boat. I ran down to the local hardware store and found something called Elmers Ultimate Polyurethane adhesive. After talking to another guy there that raved about how well it worked on his deck, I thought I'd try it. It foams when applied and is completely water proof. I did a test on a piece of 2x12 and some 3/8" ply that I was going to attach to a stand to store an motor I had removed the day before from junk boat. I was surprised at how well that stuff penetrated the wood and every seam. In about 15 minutes, the glue had foamed out of every possible seam and crack, even through a few open splits in the 2x grain. I had used some 2" stainless deck screws to attach the two on various angles and let it dry. In about 4 hours, what had foamed out the edges was dry and sandable but not brittle. I probably used far too much of the stuff the first time. It looked a lot like fiberglass resin when dry.
I bolted the test panel to a stand and imediately hung a V6 'Rude on it.
I did the same with two pieces of 3/4" ply on the jon boat, let it dry wiping over the edges well with the foaming glue while it dried. Once dry, I simply painted the sandwiched boards well with a good epoxy paint and installed it the next day.
I don't know if I'd use this on a larger boat transom or not, but I think it's a viable adhesive for boat use. It bonds to anything, even the drips on the floor won't come up and what dried on the putty knife had to be wire wheeled away. I used it to attach two small scraps together and tossed them into a bucket of water outside to see how it holds up to water. My bet is that the wood will soften and fail before the glue bond gives up.
http://www.elmers.com/products/product/product_page.asp?pCode=P9413
