Transom plate dimensions
jvel018
Hi I need a bit of help does anyone here know what are the exact dimension for the transom holes to bolt on a outboard engine, I am going to install a 225 optimax on my boat.
j_martin
Re: Transom plate dimensions
The engine should come with a BIA standard template, and a whole mess of instructions, charts, and calculations for determining mounting height and setback. You want to drill em right the first time, so it's a bit more involved than a quick how-to on a bulletin board.
Hope it helps
John
jvel018
I bought the engine second hand and i dont have the template but i have the instruction manual but on it there are no dimentions of the template, if i know the hole dimentions i can do one, Can you help me
j_martin
There are four holes, two at top, two at bottom.
Most brands use 1/2" diameter fine thread SS bolts with brass locknuts, but I have seen some Yamaha's mounted with smaller diameter bolts, so check on the diameter your engine requires. Dimensions given are bolt CENTERS. You should always draw the transom top and vertical centerline on your template.
From the top of the transom, both top holes are 1-7/8" down, and the bottom holes are and ADDITIONAL 8" down.
Top holes are a total of 12-7/8" apart, or 6-7/16" from transom centerline.
Bottom holes are a total of 9-7/8" apart, or 4-15/16" from transom centerline.
This is the universal bolt hole pattern, and applies to all brands of engines (assuming they adopted it), at least 1984 and later, from about 30HP on up to 250HP. None of this applies to OMC's blind hole option, which other brands did not use.
I copped this from another thread. I verified it with the template shipped with my XR4. I scanned the template, but the scans cannot be reduced small enough to post here.
I recommend you make the drill guide out of 2 inch dimension lumber, drilling the holes with a drill press so they are vertical. They need to be pretty close to perpendicular to the transom.
hope it helps
John
jvel018
Thank you Martin I try to work with does dimentions, I will make a wood template,
Thanks guys
