Transom plate bolt kit
Sangster21
I just bought a whack of parts from i boats. I need a bolt kit to mount my transom assembly including the lower alum bolt/ anode kit. I couldn't find them on i boats... any one know if they have them and I can't find them? The drive is an MC1.
Thanks
Alan
achris
More fish than mountain goat
Re: Transom plate bolt kit
Part number for them is -55989A8... Can't find them on iBoats...
fishrdan
^^^ That's the correct P/N, but you're going to have a cow when you hear the price, around $40
I picked up my set off Ebay for $20, after waiting awhile for a reasonably pried set to pop up.
Ayuh,.... I think they're OEM replacement,... Only...
Sangster21
I hope I ordered the correct item. I ordered from ebasic power the anode bolt kit.
http://bpi.ebasicpower.com/pc/MER55989A8/MER2E
I also ordered the new engine mount bolts with fibre washer and spring etc. Can I use SS threaded rod to make up studs for the rest of the transom plate fasteners or are they also OEM only?
Thanks
Alan
Don S
Get the right studs, NOT all thread rod.
Sangster21
OKey dokey , is this Mercruiser only item? If so is there a good online source for them?
Thanks,
Alan
Bt Doctur
And to think back in the days of 100 miles to a parts dealer we would just take some rod stock, cut and thread it to the correct size.
Sangster21
Thank you for the help, I will order up the appropriate fasteners tonight. Hopefully I don't forget something and the install goes smoothly.
Regards
Alan
