Re: Transom Core Replacement Only
The seacast results I have heard of have been 50/50 good/bad. I am sure it is a good product, but I think there are too many application variables when us amateurs are installing it. The failures that I have heard about have been the result of a poor or non-existant bond between the seacast and the skins. It seems reasonable given the crud that exist in rotted transom cavities. In the right situations, I am sure it is a very good solution.<br /><br />I think the more traditional methods are still the best. You can choose between plywood and a structural foam, but I would always use epoxy.<br /><br />garrett61: You are correct. Replacing a transom is an invasive procedure regardless of the method. For me, I know I can get good results with plywood, epoxy and glass and will go that way on my new project (actually I may have no choice since of the project boats I am considering has very little transom remaining). <br /><br />It is a lot of work, but you will save a lot of money doing it yourself and you will feel a great sense of accomplishment when you are done. <br /><br />Good luck with the project,<br />Dan
